We have some rare items in Australia, including some of the residents! This tractor is for sale by auction and is described as "Rare genuine factory 6 cylinder diesel Fordson Major". How many of these in the UK?
The auction was yesterday, sorry, but if you want to have a look, go here: http://www.nolanfleet.com.au/currentauction.html
Could be buildt in some pivate factory but sertainly not in a Ford factory. The A-frame is missing and the front axle will not take the normal stress without it. If the oilpan is the original aluminium and without added frames it will brake in half.
How can you say that, I showed you the picture! Just kidding.
I have read that Ford in the UK were totally opposed to fitting the larger engine, so I doubt if Ford Australia did such a conversion. I just thought it was an interesting topic of conversation.
Roadless made 23 Majors with the 6 cyl engine from May 1961 to 1964 for export, badged as Ploughmaster 6/2 so no one of them remain in England and this is not one of them either .
If you go to my story "Winterswijk 2007" in the Wiki, there is a picture of one of the Supers with a 6 in that I meant. You can see that they have done a great job with the sump and mounted the "wishbone" back where it is on a standard Super. This is a "proper" sump and not a modified one, it is cast in one piece.
Some really clever welders take two Super sumps and join them together to get the same result.
Eric, I think that during the early 1960's Napier Bros in Dalby Queensland who were the the Ford dealers and also manufactured a large range of implements and Machinery, many of which were marketed as Ford and painted Blue. They were responsible for fitting up some 6 cylinder conversions back then but they may have only been built to customers orders - I don't know. The tractors that I saw all had a distinctive join in the Bonnet and in the chassis rails. Napiers also set up a lot of tandem Fordsons as this set-up was the cheapest way to get 100+ horsepower. Best regards - Michael.
I had a look at that tractor. Its a home conversion with an industrial 590E engine. Its a 62 Super Major non live drive with HD clutch, external greaser.
Engine is a bitsa. Its a late 62 cast with FL head but has the early pump.
Rear wheels have been widened with huge tyres for pulling.
The tractor had no wish bone so the front axle was all sloppy.
It was passed in, did not sell at $6k. Last year I passed up a similar tractor with a turbo Dover engine.
The best tractor at the sale was a late 1953 E1ADKN with square PTO box. Very nice.
Steve
PS, how do I get into the Wiki? Ir wont accept my name or password.
Saw the tractor in question today at the Ballan Vintage Machinery Show. It did a couple of pulls in the tractor pull. Up close it is an obvious Bitsa, the front axle only just hangs in there. If it was not being tried to be passed off as a Super Six I would give it credit for being a nicely turned out six cylinder conversion that runs real well. I have no idea why the front axle has not been fitted with the wish bone. The sump on the tractor is shallow enough for a frame to be made up that goes from side rail to side rail that would hold everything in place. Maybe that would give it away as not original. I did get the impression that the owner was looking for a buyer when he did his run. He almost managed a full pull, but too much throttle and a lack of skill in the last few yards probably let him down. I felt sorry for the bloke on the sled though, after the steady and measured pace of the other competitors, this guy just took off like a rocket. At the end he came to such a sudden stop that the weight continued up the rails to the full pull position even though he only got to about 98 yards. It was still no match for the 70 and 90 Hp Chamberlains. A great day out though.
essex pete wrote:Ahhhh! An antipodean Doe. Wonder if there are any pictures kicking about.
Not Doe-like, but this type of tandeming was common in Australia. This conversion kit was available from your friendly, neighbourhood Fordson dealer. I took this photo at a Fordson field day on a farm not far from home.
The one shown in all the Marshal books is the one I would have liked to have seen. Two Field Marshals coupled in a similar frame.
The normal tractor would rock you to sleep and shake everything to bits if you left it ticking over. What two together in the same frame would have been like is frightening!
There was 3 of these that came out in 62 one had normal rims, one had duel wheels and this one which had 6" put in the rims, we were trying to sell it cause it wouldn't pull but the gavenered shaft wasn't free we still have her to this day
