FNM Front wheel studs
Hi i need some wheel studs for my FNM but i don't know if i need the ones with the splines or the ones with out them how can i find out what ones i need ?
anthonygos
Re: FNM Front wheel studs
By taking one off. (out)
Don't just leave it in the shed, Fordson's are made to work, so take it out and work it....!
you see they are already out i cant find the old ones
Got some new ones today but they seem to be two short is there different lengths in them ?
yes there is. Are yours about 10mm to short? I hink the spline angle will also be different.
yes the ones i got are to short the old ones had no splines on them as far as i can see
So what lenight should the wheel studs be?
