My Super Major won't lift anymore. I have a manual and there i followed this troubleshouting:
I have removed the plug and when i turned engine with starter i had no oil flow coming out, did i checked at the right plug?
So next i have taking top cover off, then i checked the feed line and there was pressure when i blocked it off with my finger while cranking the engine, don't know iff the pressure was high enough as i don't have a tester... But i thought maybe i schould point my attention to the top cover as there was no oil coming out off the plug.
So i began reading alot on forums and then i came acros this forum where i have read topics from Majors with hydraulic problem specially the ones where the lift doesn't come up like mine, from what i can read many people suggest to look at the flow control valve.
The retainer cap and spring came out but don't really know how to get the valve out and if there is one or not...
Is the valve really located behind the spring as in the image?
In the manual they talk about selective fit, can somebody explain further, is that a very tight fitting? Could there be rust some sort of deposit in between that blocks it from coming out?
I have tried a few things to get it out:
i have disasembeld the whole top cover, and put the thing a few days i dieseloil: no result
then a day in wd40: no result
i have heated the top cover: no result
Somebody have any advice for me?
many Thanks Maarten
