What is the correct start procedure for a diesel Super Dexta?
The operators manual mentions..
1. Ensure that the fuel supply tap is turned on. The main supply is available when the supply tap is unscrewed two turns.
2. Check that the main gear lever is in the neutral position.
3. Ensure that the stop control on the control panel is pushed right in.
4. Insert the main control key in the switch, turn to the right and check that both-warning lights become illuminated.
5. Move the throttle lever in a clockwise direction to slightly more than the half open position.
6. Press the induction primer button once only to inject a small quantity of fuel on to the heater plug and depress the heater button for forty seconds.
7. Depress the clutch pedal fully and, with the heater button still depressed, operate the starter motor by pushing the starter control lever downwards. Pump the primer button two or three times as the engine is being turned over by the starter motor, when the engine should start.
8. Release the starter control lever and the heater button immediately the moment the engine starts and adjust the engine speed by means of the throttle lever. If the engine does not start, wait thirty seconds and try again. Always ensure that all moving parts come to rest before attempting to re-engage the starter motor otherwise damage may occur.
But I believe the Super is different as it has a mechanical governor and injector pump?
After some reading there has been some mention about
1. Depressing the excess fuel button on the injector pump.
2. Open in the throttle ½ to a ¼,.
3. Depressing the primer button,
4. Pressing the glow plug heater button and then
5. Cranking the engine?
Only a few problems, mine doesn’t appear to have the heater button?
It has a light, (lower right) which illuminates when the key is turned to the right. Above that, what I figure was once a horn button (It doesn’t appear to do anything now) and on the left a simple on/off light switch, which illuminates the Proof meter, and above that, a pull stop button.
So where is this mysterious heater button? Did the Super not come out with one? Has mine been modified sometime in the past? Or does the glow plug automatically heat when the key is turned and the light is on? Once the tractor is started I can turn the key back and the light goes out, seemingly without affecting anything.
It looks like the glow plug it still connected, but I’m not sure as yet if it’s actually working.
I’ve tried removing it to check but at the moment it just seems to spin and not come out.
The wiring on this old girl is a mess to say the least, most has been disconnected (Simply cut off really). There are no head or tail lights and the temp gauge and warning lights on the dash are missing. I am in the process of replacing what there is still connected with new stuff, but it’s hard to tell what was original and what has been jury rigged. (There is just a roll of disconnected wiring) The only things that seem to be connected are Battery to solenoid, to the switch at the crank lever, to the generator and starter motor etc.
I haven’t traced it all back to the control box yet as I haven’t been able to easily get in there.
I have the wiring diagram from the manual but if the Super is different from the Dexta (As it appears to be) then I’m not sure I have too much faith in it.
Also I assume there was once a primer here, but this is all that is left.
Is it just a matter of inserting some sort of plastic pump bulb, like from a chainsaw or something to fix this?
I haven’t had too much of an issue starting her normally, but just recently in the cold, 1 or 2 degrees C, and with the lack of help from a dying battery, it’s been a lot harder. (I’m not sure it’s charging the battery either..)
While I’m here and replacing things…
I assume this is where the temperature gauge should be connected? Is it just a case of removing this stump and inserting a new one? There appear to be some on E-bay? I even have a spare from an old International 434 which might fit?
Again with the Proof meter cable, as simple as removing and inserting a new one?
Anyone know if the gauges and meters advertised on E-Bay from India are any good?
Thanks all.
