hello there
I have a 56 major with the depth control thingy that works from a cam fastened to the end of the lift arm cross shaft.
I pulled it all to bits to free it off & paint it,then discovered I had lost the cam
Does anyone please know of the wherabouts of a cam
thank you
Re: depth control thingy
You have heard the saying about hens teeth and rocking horse manure? You are more likely to find both than a cam for that system.
They were an optional extra and very few were ever fitted. I do have some parts for one like the long rod that moves the lever and the adjuster plate but I am pretty sure I do not have the cam.
Will look in a few days and let you know.
Thanks brian
I saw one on a tractor that my mate made into a tractor puller,
but he sold the tractor before I could cadge it.
I guess we could make one if we had one to copy
Internet wants pictures of that interesting extra equipment.
1958 Major
1961Selene 4wd (project)
dept control, designt for the ransomes TS73 plough ( with no dept wheel )
the right one is ready, the left one is under construction
the plate
This Major has full options
Is it yours Janus?
no henk it is not minehenk wrote:This Major has full optionsIs it yours Janus?
have taken this picture in panningen this year, because of the full option , i think it is very nice
hello there
Yes that's the thingy that I had in mind. will have to go to Malvern & see if I can find one
