The reason I am asking is, when the lift arms are in the lowest position, the linkage is pushing the main control valve in by at least 1/4 of an inch, and the quadrant will not move to its highest position because it's like its pushing the control valve too far? (Hope I am making sense)
It is almost like I have not done the position control spring up enough
Obviously the lift is not on the tractor, its upside down on my bench
