TO ALL FORDSON ENTHUSIASTS;
I am completely surprised. it is like this i overhauled my FSM by fixing the liners, piston and rings. i did not touch the cylinder head as it looked fine to me. but after firing it up i worked with it for just not less than a month. just last week when i switch it up i noted that the oil is coming out of the exhaust manifold. any idea of the possible cause of the prboblem.
cheers
FSM ENGINE PROBLEM
oehrick
Re: FSM ENGINE PROBLEM
Have you checked the rocker box breather pipe back to the air intake filter is free and working ? often overlooked cause of excess oil in exhaust and can result in oil or slime escaping through the block breather. Failing that maybe it's a valve stem sealing problem.
Hi Rick;
THANKS for your valuable reply. i will follow what to commented and give a feedback.
Dear Kissamo
You say you "fixed" pistons, liners and rings. I presume you meant that you have renewed those items. You also say you have used it for less than a month. You do not say how you have used the tractor in the month since. If you have not "run-in" what is effectively a new engine by giving it some really hard work, then it will throw out black oil through the exhaust at intervals. It needs a few days of really hard work (ploughing) or better still, put it on a dynamometer and give it a couple of hours at maximum power.
I had a similar problem with my Super Major after rebuilding the engine last year. It had some work, but not hard enough. I put it on a dynomometer at a local agricultural agents earlier this year. It started off at 41HP at 1800rpm and at the end of 2 hours, it was producing 45.9 HP at 1800rpm at the PTO. (Given transmission losses, this equates to the specified 52hp) The engine has been brilliant since, no oil out of the exhaust, although the silencer looks like it has been in a furnace!
So your "rebuilt" engine needs some brutal work to burn the paint off the silencer to effectively run it in.
Timeee
Timeee
DEAR TIMEE;
THANKS ALOT FOR YOUR GOOD COMMENTS. I HAVE ORDERED VALVE KIT AT AGRILLINE. I WILL PULL DOWN THE CYLINDER HEAD AND FIX THIS KIT THEN I WILL SUBJECT IT INTO A MAXIMUM HARDSHIP
CHEERS MY FRIEND
ELIAS KISAMO
CHEERS MY FRIEND
ELIAS KISAMO
