oil leak
oil leak
Help! Due to ill health tractor not moved for nine months. Now started once again and there is a bad oil leak at the services it is just above the end of the qualtroll lever, it's the opening with the pin in it. Never done this kind of thing before, can anyone help with advice?
Re: oil leak
just found out, it's where the flow control valve is housed
Re: oil leak
I see it's the same problem as Terry 274 , hopefully the answer will come up on his or my site
Re: oil leak
Brian I suggest to discuss this further on in the the other thread started by Terry
Re: oil leak
Thanks Mathias, however this is the first time my tractor has moved in nine months and I am desperate for some fun
Re: oil leak
unit off soaking in release oil ,waiting on seals and gasket coming
