Hydraulics issue
FerdiNL
Re: Hydraulics issue
Post by FerdiNL »
mathias1 wrote:
Fri Jun 25, 2021 11:41 am
use draftcontrol when operating your front lift!
I know :)
Until I've changed the lift cover the front loader was working okay, but after since the most power is lost.
FerdiNL
Post by FerdiNL »
Haven't had the time to play with the heavy weight,but so far so good.
With the new hydraulics block the front does have more power, hopefully enough to lift the same amount as it used to do.
Glad to hear you have it sorted, hopefully it will lift all you need it to
FerdiNL
Post by FerdiNL »
Today was the big day, they came with some hay.
But...the Dexta managed it all so things are sorted :)
