Length of Fordson Dexta clutch adjustment rod
Re: Length of Fordson Dexta clutch adjustment rod
Great pics Illka! Shows the results of using the wrong parts
I can't see the pics. It does sound like repro parts are getting worse.
The post has vanished! There were 2 pics of a destroyed thrust bearing and adjuster bolts in a dexta clutch that lasted 2 hours after fitting the wrong bearing
I can see the post but not the pics. Sounds very odd.
Sandy, here are the pics Illka posted of the release bearing
Wow. That’s not good.
New lever screws needed too. What a disastrous bearing, it shouldn't be that difficult for them to make the correct bearing.
IlkkaV
Post by IlkkaV »
From Finland I can't find any dealer where to buy new lever screws. Do anyone have ideas where to order those screws in europe?
BR
Ilkka
I think you'll need to find a scrapy with a good set on a clutch.
Hi Illka, try messaging Railswood Tractors, they may be able to help
https://www.google.com/url?sa=t&source= ... 6gpJpeicic
Bluebilly
Post by Bluebilly »
Try Richard Pocock, I've used him several times and he never let me down yet...well worth giving him a call
http://www.pocock-tractorsupplies.co.uk/used_parts.html
Grey Fergie
Ford 2000 - Pre-force
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
MF 20B - Industrial with 7 gang mower
SAME Solar 60
