I also wanted to change the oil seals of the gearbox shaft.
Not an easy job :s
yes It's the new type. will make a picture while fitting it.
Well the brick pavers are a bit a pain in the ass to move the engine crane.
No need for draining the oil, is really a relief. with the underbeam of the county it's a messy job.
Shepp, it is originally an early 1963 super 4. I got this info from the County -Osbourne company. They checked the county serial number. At a later stage it got the 6cil industrial engine fitted. The same engine is usedin the ford 8100, that was built by County.shepp wrote: ↑Wed Apr 26, 2023 11:44 pmIs it a very late County Super 6 because it has the later engine in it and not the 590E that most were fitted with?? County it is believed bought up a years supply of skid units when Ford announced they were discontinuing production of the Major range, and this enabled this model of County to be produced until late 1965. However the 590E engine continued in production until 1967 alongside the new type industrial engines, so is it that it has simply had an engine change?
