Instead of buying a complete levelling box at forty quid i have got just the worm for £6. Problem is, how do you get the worn one out and the new one in? Answers on a postcard, please, first correct entry wins a prize.
Steve.
Levelling Box Puzzle
hi
from memory theres a split pin holding in the cross pin of the swively bit ( technical term!!) take out split pin , knock out bigger pin removing swiveley bit. then unscrew the circular plug ( Brian called it a welsh plug) on the top of the arm then all should be clear come apart.
hope that helps
hope that helps
Mike
It did eventually tap out but it was a hell of a game. When i looked inside, it was the bearing that was shot and not the knuckle after all, it's in perfect order. I should have dismantled it before ordering the knuckle but i assumed it was that that was the problem. Might order some Hindsight when i order the bearing, but having said that, i might buy that and find i don't need it !!
Thanks for the help chaps. Steve.
