At what engine RPM will 540 RPM be attained for the PTO? On the proofmeter, 1800 engine RPM is marked as "S.T.D PTO". This seems rather fast.
What would be the optimal speed for fuel economy and least engine wear?
Thanks,
Terry
engine R.P.M vs. P.T.O speed
1964 Fordson Super Dexta
1800 rpm is 540. That is the engine speed that is best for the engine when under load. It is between max hp and max torque and the engine should be run at around this speed when in work to get best fuel consumption, best wear charicteristics and long engine life.
Too low revs/light work =
Worn out engine.
Too many revs with no load/ engine not being worked =
Worn out engine.
Full load at 1800 revs =
Happy engine for many years.
We are lucky we do not collect John Deere tractors. The PTOspeed for 540 comes in at 2600 rpm. It used to be painful to set them up on fertilizer spreaders!
Hello Brian
It is correct on Dextas after aug. 1960 with a ratio of 3,33:1. Earlier models had a ratio at 2,89:1. That means rated speed of 536 rpm at pto with 1550 engine rpm. You can see what kind it is with the black knob at the hi/low lever. the old one don't have that.
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
