Hello
can anyone help, after solving my overheating while using my new flail-mulcher by fitting a fan cowl and giving the rad. a good blow through I went to work with the flail again. For about 40 mins everthing was fine but then gradually she started to loose revs and after 5 mins I had to stop. Now I think it good possibly be the fuel filter or more accurately I hope it is just the fuel filter. There doesn't seem to be any other symptoms. Could anyone give me confirmation or a clue?
Regards Rob
Power drops
Thankyou for your replies, I have got a reproduction primer pump/tap and it is very poor. I replaced the fuel filter and had a look at the tap by unscrewing it out to find what looked like cow hair bunged up in it. It seems that this has cleared it but I fear the problem will return unless I drain and clean the tank, regards Rob
