Where does this fit on the brakes?
EddieJ
Post by EddieJ »
Hi All. Having stripped the brakes down on one side I was looking through some spares catalogs including Emmark and Sparex and have seen this:
Sparex describe it as "DUST COVER-BRAKE Rubber Boot"
Does anyone know where this fits? I havent seen this during removal of the brakes or in the old parts catalog.
Does it fit on the back plate as a boot for the brake actuating cam shaft? We're hoping it may be a modern replacement for the spring and washer mounted on the end of the cam shaft that pushes on the outside of the back plate. The spings we have are destroyed. :x
Rich & Eddie
Tubal Cain
Site Expert Team
Site Expert Team
Post by Tubal Cain »
It doesn't belong on a Dexta, I guess it may fit on a Major!
Gerald
Bensdexta
Post by Bensdexta »
EddieJ wrote:We're hoping it may be a modern replacement for the spring and washer mounted on the end of the cam shaft that pushes on the outside of the back plate. The spings we have are destroyed.
It should be possible to source another spring - I got one for my Dexta from my local ag mechanic.
All the best,
marlyman
Post by marlyman »
yes, thats of a major, and it also fits a leyland.
EddieJ
Post by EddieJ »
That makes sense, I now remember seeing it on the Major page at Agriline. Same photo so i assume they are all sourced from Sparex and if they have it incorrectly marked for a Dexta most dealers probably followed suit.
marlyman
Post by marlyman »
her is the origional parts diagram showing the seal, only on a super major from the ford cd's i have.
http://www.qtponline.com/files/major.pdf
btw if anyone wants any parts diagrams just ask.
EddieJ
Post by EddieJ »
Help...
We are now in desperate need to source a couple of thes conical compression springs for the brake actuating cam.
Local NH stealer; Murleys in Warwick dont stock them, two other local Ag engineers havent a clue.
We enquired about getting them custom made but our cheapest quote was £85 for min order of 20 - we only want 2!
Currently we are fashioning a workaround solution but in the words of the 'Barley Pickers' we would prefer the "proper job"
This is the beast:
Bensdexta
Post by Bensdexta »
I assume you still have the washers part# 24?
I don't think there is anything very special about the spring. My ag man said he managed to find 'something suitable lying round his shop' - works fine.
Nice work on your refurb :wink:
EddieJ
Post by EddieJ »
Sorry.. yes we have the washers, but they would be easily manufactured.
pottyperkins
Post by pottyperkins »
If you have no objections to shopping with a rival brand
The springs are available from you local massey ferguson dealer, they are for a mf 135
marlyman
Post by marlyman »
which spring do you mean ?
Bensdexta
Brake Rod Spring
Post by Bensdexta »
marlyman wrote:which spring do you mean ?
I think the spring EddieJ is seeking is:
All the best,
EddieJ
Post by EddieJ »
Thanks pottyperkins for the advice. :idea:
We got on to our local MF dealer (BRUCE HOPKINS Ltd in Hinkley) this morning who low and behold had some of the very same on the shelf at their sister branch in Long Buckby Northhants.
The image below is the old and new springs:
As they were only £0.51 we got four :D
Bensdextas shows a good image of them fitted, but as you can see there was next to nothing left of our old ones.
marlyman, most those parts on your image look like they are for a Major, thanks for the help.
Thanks all.
Mervyn Spencer
Post by Mervyn Spencer »
Hi, I know exactly where those springs are on the tractor but have no idea what there purpose is. Can someone please enlighten me as to what they actually do?
Bensdexta
Post by Bensdexta »
Mervyn Spencer wrote:Hi, I know exactly where those springs are on the tractor but have no idea what there purpose is. Can someone please enlighten me as to what they actually do?
Mervyn,
AFAIK they just keep the washer snug against the brake back plate, to cover up the gap around the rod & stop the dirt getting in. Crude but simple!
Hope your weather is warmer and drier than it is here just now :wink:
All the best,
Mervyn Spencer
Ben
Thank you for the explination, I will have a look at the springs on mine over the w/end.
We have also been experiencing some strange weather lately. A lot of good soaking rain. There are areas in the north and south of us that are experiencing drought. This last w/end it was reported that snow had fallen on the very high peaks of the Drakensberg mountains which is a beautiful range of mountains that runs from the south through to the north of the country. Our temp for tomorrow where I live, is predicted to be 33 degrees centigrade plus rather high humidity. Isolated storms are also predicted later in the week.
Until next time keep well.
