Levelling Box Puzzle
Ambidextarous
Post by Ambidextarous »
Instead of buying a complete levelling box at forty quid i have got just the worm for £6. Problem is, how do you get the worn one out and the new one in? Answers on a postcard, please, first correct entry wins a prize.
Steve.
Remove the handle, gear and welsh plug on the top and it just lifts out. Should be a 10 minute job! :twisted:
MikeR
Post by MikeR »
Brians right even i managed it in record time!! :lol:
Mike
Ambidextarous
I've chucked it across the shed. I'll have another go when my patience returns :evil:
Stefan
Post by Stefan »
Ambidextarous
Thanks for the pics Stefan, it's only the pin holding the handle that i'm having problems with, it just doesn't want to shift.
Mervyn Spencer
Post by Mervyn Spencer »
Hi Steve
Is that pin not possibly a tapered pin?
Mervyn
MikeR
Post by MikeR »
hi
from memory theres a split pin holding in the cross pin of the swively bit ( technical term!!) take out split pin , knock out bigger pin removing swiveley bit. then unscrew the circular plug ( Brian called it a welsh plug) on the top of the arm then all should be clear come apart.
hope that helps
Mike
Ambidextarous
It did eventually tap out but it was a hell of a game. When i looked inside, it was the bearing that was shot and not the knuckle after all, it's in perfect order. I should have dismantled it before ordering the knuckle but i assumed it was that that was the problem. Might order some Hindsight when i order the bearing, but having said that, i might buy that and find i don't need it !!
Thanks for the help chaps. Steve.
