Spin-On Oil Filter
Spin-On Oil Filter
Post by Bensdexta »
Is anyone using a spin-on oil filter on their Major?
If so what type/spec is it?
TIA :wink:
origin
Re: Spin-On Oil Filter
Post by origin »
is there an oil filter housing that will bolt to the Major engine, to allow spin on filters?
1962 Fordson Super Major w/ Robin FEL (6' rough cut mower)
1978 Ford LGT 165 (w/ 42" Mower, 36" Tiller, and 48" Plow)
1976 Ford LGT 165 (Parts Tractor)
1974 Ford LGT 145 (50" Mower, 42" 2 stage Blower, Sleeve Hitch, Cultivator)
Post by Bensdexta »
origin wrote:is there an oil filter housing that will bolt to the Major engine, to allow spin on filters?
On 2nd thoughts, you may be correct - there isn't one! :(
There is for the 1000 series, and a MF35 spin-on filter head will fit a Dexta, but there seems to be an opportunity for some one to produce one for the Major.
Post by Dandy Dave »
I have not seen one for a Major as they are a different animal. I do know that you could get an adapter for seveal years ago for the Ford 9N,2N,8N, NAA and the early number series. It was the same adapter that was used on 1950's Ford cars and trucks and used the same spin on filter. Dandy Dave!
Here it is.... http://www.fixthatford.com/index.php?ma ... 7ac808c25c
origin
Post by origin »
If the engine is a 4D engine, then it looks like this filter housing might fit
http://www.boatsandoutboards.co.uk/engi ... ord-LCM193
super6954
Post by super6954 »
origin wrote:If the engine is a 4D engine, then it looks like this filter housing might fit
With the tractor engines you have to make sure there is clearance between the filter and frame rails. I have the newer industrial 4 cyl with this type filter on :!: .
To get it to fit inside the frame rail I had to cut half moons out the top and bottom of the rail :cry: . My filter is not that bigger diameter either maybe 4.5" or so :eyes: . the original slim major filter is pretty tight to the side. A spin on is probably an inch + bigger diameter :wink:
With a boat basically as long as the motor mounts are not in the way ,and it don't hit the sides of the hull you have no problem with clearance :idea: .
Just thought Id let you guys know the problem before you all get to excited, and rush off for a kit and find this out :wink: .
Kiwi Kev
Post by Kiwi Kev »
super6954 wrote:
origin wrote: Just thought Id let you guys know the problem before you all get to excited, and rush off for a kit and find this out :wink: .
It doesn't take much for us to get excited :lol:
"Classic Contracting"
International 784 4WD
& looking at another tractor!
