This post is in reference to my "hydraulic lift problem" four posts below.
I took the lift cover off today. The unload valve was stiff coming out of the bore. I cleaned it and replaced the O-ring. I also cleaned the control valve. It did not seem to be gummed up very much. Put everything back together and the lift worked.
Now I just hope it stays working!
Thanks for all the help and suggestions from everyone on this board.
Terry
it was the unload valve...I think
1964 Fordson Super Dexta
