Dexta Register.
Dexta Register.
Chaps,
If you post your Dexta engine, Serial Numbers, casting codes from Clutch Housing, Gearbox, Rear axle, Hydraulic lift and axle shafts, I will pick them up and compile a table like the Petrol Dexta Register.
I would suggest no names just country and logon name.[/b]
roromac
Post by roromac »
This could turn into something big
1962 Super Dexta
S/N 09B720237
Engine 1606974
Clutch H29H
G'box L4H
l/h axle K10H
r/h/ axle K10H
hyd top J10H
1964 NP Super Dexta
S/N 09D 925069
Engine 1661923
Clutch 4G3
G'box 4D28
l/h axle D4J
r/h axle D(unreadable)
hyd top 3E20
Rob
GERRY
Post by GERRY »
Here,s my standered dexta serial -957e 10388 engine 1414828 Gear/box H-30-B trans H-23-B Back axel J-1-B Hyd/lift/cover -M-13-B The lift seems to be 3mth later than the rest of tractor ? the rest is all around June /July GERRY
Jos Cuypers
Post by Jos Cuypers »
Standard Dexta :
Engine : 1532299
Serial : 09B778483
Clutch Housing : J1H
Gearbox : J5H
Rear End : no casting code
Lift cover: J3H
Left Axle : H28H
Right Axle : J3H
Narrow Dexta :
Engine : 1455656
Serial : 957E44870
Clutch Housing : P2C
Gearbox : M27C
Rear End : N20C
Lift cover: N27C
Left Axle : no castingcode
Right Axle : no castingcode
Rgds
Jos
niallsdexta
Post by niallsdexta »
Hydraulic Casting 957B501E/T6
Gearbox Casting 957E7005/T3
Back Axle (Left) 957E4013B/T4
Back Axle (Right) 957E4013B/T2
Engine Block Casting GKN13721G137219
NVNL
Post by NVNL »
1964 Super Dexta
S/N 09D 914915
Engine 1653147
Clutch
G'box 4D9
l/h axle
r/h axle
hyd top
Richard
All manner of things shall be well.
1964 Super Dexta
1960 LE
1969 T100C
1981 T140ES
1993 MT350
All will be well and all manner of things will be well.
Chris Ivin
Post by Chris Ivin »
1960 Standard Dexta
Dexta engine No. 1460974H(Now in corner in shed due to cracked block)
Serial No. 957E 61030
Clutch Housing = B2D
Gearbox = H9D
Rear axle = H9D
Hydraulic lift = F31D
Axle shafts: RH = D13D, LH = F25D
Chris
Brailes, UK
"Dexta's rule the World!"
EddieJ
Post by EddieJ »
1962 Super Dexta
S/N: 09B725689
Engine: 1610947
Clutch: M9H
Gearbox: M4H
Left Rear Axle: M4H
Right Rear Axle: K23H
Hydraulic Top: L27H
Dexta 1
Casting Code L7 F clutch housing: (F almost unreadable)
Serial No. 09B 7?1617 (not guarantee on the number, but the 09B is correct)
Dexta 2,
Casting code clutch housing: M8C
Serial No. 957E 42718 (behind the E barely readable)
greendoglive
serial numbers
Post by greendoglive »
Dexta 58??????????
engine 2ckk1372
injectors spe3a605402
957e 7905
c25b
what is my motor and why do the numbers seem to not be found anywhere. The number i obtained from left side near firewall just above sump.
any help greatly appreciated as I am planning on engine work very soon hopefully.
Dexta 1958?
957E 7905
C25B
Please do not post queries on here. It is only for a record of tractors.
Numbers like the ones shown are not serial numbers, they are casting numbers and are the same on all tractors. The only numbers cast into castings that mean anything are the C25B that you quote. This dates the component at March 25th 1958 so she is fairly early being three months into full production.
You need the code from the flange behind the starter and as many of the casting codes from the other parts as you can find,
Erik B
Post by Erik B »
Hello Brian, thanks a lot for the work you do for us Fordson nerds.
Have been a "hangaround" for a long time, reading the forum and learning a little every day about our old beautys... Live on a small farm in Norway, my Dexta has been mine since 1997, my father bought it in 1966. She is a 59 mod diesel, original with a Horn Draulic loader on. However she was stripped for all that for about 35 years ago.
Serial nr 957E 26259
Engine nr 1427175
Hydr. lift B6C
Clutch housing B23C
Gearbox A29C
Left Axle shaft B23C
Right axle shaft B18C
Rear axle B18C
kiwiland dexta
Post by kiwiland dexta »
1961 standard Dexta
Serial# 957E92647
clutch K24F
hydraulic cover L6F
L axle L21F
R axle M11D
Gearbox J20F
Engine 1492941
Cheers, Brian.
A.B.Ames
Post by A.B.Ames »
1962 Super Dexta (w/Ford 2000 sticker on sides)
S/N 09B720950
Engine K72 (plate w/2 screws), 1607571 stamped, 37111510 raised
Clutch K14H
Gearbox K16GH (also a 957E 7??5)
Hydraulic J31H
L-Axle K14H
R-Axle K14H
(note my axles were marked on the rear side not the front as the ser# post said "the rear axle casting code, located on the front side of the rear axle.")
Let me know if I missed anything, or error'd in anyway.
Many Thx,
A.B.Ames
commander
Post by commander »
1959 Dexta - live pto
serial (957e) 43991
engine block 1445023
LH axle M6C
RH axle N2C
Hyd cover M30C ?
clutch housing M28C
In South Carolina - USA
Jack
The Swanndri Guy
Post by The Swanndri Guy »
1963 Fordson Super Dexta
Serial number 09C 904603
Engine number 1622951
Clutch C11J
Gearbox B26J
Rear housing C5J
Lift cover ?
Left Axle A10J
Right axle D8J
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Post by Bensdexta »
Serial number 09B719xxx
Engine number ?
Clutch H26H
Gearbox K2H
Rear housing ?
Lift cover ?
Left Axle ?
Right axle H21H
1961 Standard Dexta
Serial number 09A313xxx
Engine number 1495xxx
Clutch N15F
Gearbox L26F
Rear housing N15F
Lift cover N10F
Left Axle N10F
Right axle 22J4 (?)
Unknown Dexta
Serial number 09C910127
Engine number ?
Clutch D2J
Gearbox 3D23
Rear housing ?
Lift cover ?
Left Axle ?
Right axle ?
Clutch housing & gearbox only
Chug-A-Lug
Post by Chug-A-Lug »
S/N: 09D918971 [1964]
Engine No: ZGKN1372
Clutch Housing No: 4E15
Gearbox No: 4D28
Rear Axel No: P7H [Dec 7th 1962]
Hydraulic Lift No: N29H [Nov 29th 1962]
Axel Trumpet UK Passenger Side: P4H [Dec 4th 1962]
Axel Trumpet UK Driver Side: M11H [Oct 11th 1962]
GERRY
64 super dexta
Post by GERRY »
superdexta
serial no 09D926230
engine no 1631258
clutch no 4D22
trans no 4D20
axel right 3G2
axel left 3J28
hyd lift cover 3M18
russelm
Post by russelm »
1959 Standard Dexta:
Serial Number: 957E26216
Engine Number: 1427217
Clutch Housing: 957E 7505 7B16C
Gearbox: B17C
Rear Axle: B18C
Hydraulic Lift: B20C
Left Axle Trumpet: B18C
Right Axle Trumpet: B18C
Frustrated
Post by Frustrated »
1961 Standard Dexta:
S/N: 957E86436
Engine: 1487184
Clutch: H16F
Gearbox: H8F
L Axel: H12F
R Axel: H13F
Hyd. Lift: H13F
My Dexta has had a hard life.... Now it's time for some much needed TLC
woodseaves
Post by woodseaves »
1960 Standard Dexta
Serial Number 957E59502 July 1960 (Approx)
Engine Number 1456118 H
Gearbox F25D May 25th 1960
Rear Axle RHS B24D February 24th 1960
Rear Axle LHS D27D April 27th 1960
Hydraulic Lift Casing F27D May 27th 1960
Casting 2GKN1372
hervold
Post by hervold »
Dexta Special :
Engine : 1548096
Serial : 09D 912897
Clutch Housing : 4D7
Gearbox : 4C18
Rear End : ?
Lift cover: ?
Left Axle : ?
Right Axle : ?
Jan
npaulz
NZ Blue
Post by npaulz »
Blue and red.
Serial number: 09C 908157
Engine number: 1625612
Clutch: M26H
Gearbox: A31J
Rear housing: C 4J
Lift cover: C 4J
Left Axle 3J10 (I swear this is correct. Casting is 957E4013B)
Right axle B27J
Taggart
Post by Taggart »
April 1962 Dexta
Engine- 1508725
Serial- 09B710457
Clutch- D9H - April 9th 1962
Gearbox- D17H - April 17th 1962
Liftcover- ?
L Axle - D16H - April 16th 1962
R Axle - D8H - April 8th 1962
