Dexta Register.
Dexta Register.
Chaps,
If you post your Dexta engine, Serial Numbers, casting codes from Clutch Housing, Gearbox, Rear axle, Hydraulic lift and axle shafts, I will pick them up and compile a table like the Petrol Dexta Register.
I would suggest no names just country and logon name.[/b]
				Jos Cuypers
Standard Dexta :
Engine : 1532299
Serial : 09B778483
Clutch Housing : J1H
Gearbox : J5H
Rear End : no casting code
Lift cover: J3H
Left Axle : H28H
Right Axle : J3H
Narrow Dexta :
Engine : 1455656
Serial : 957E44870
Clutch Housing : P2C
Gearbox : M27C
Rear End : N20C
Lift cover: N27C
Left Axle : no castingcode
Right Axle : no castingcode
									Engine : 1532299
Serial : 09B778483
Gearbox : J5H
Lift cover: J3H
Left Axle : H28H
Right Axle : J3H
Narrow Dexta :
Engine : 1455656
Serial : 957E44870
Gearbox : M27C
Rear End : N20C
Lift cover: N27C
Rgds
Jos
						Jos
				niallsdexta
				Chris Ivin
1960 Standard Dexta
Dexta engine No. 1460974H(Now in corner in shed due to cracked block)
Serial No. 957E 61030
Clutch Housing = B2D
Gearbox = H9D
Rear axle = H9D
Hydraulic lift = F31D
Axle shafts: RH = D13D, LH = F25D
Gearbox = H9D
Rear axle = H9D
									Chris
Brailes, UK
"Dexta's rule the World!"
						Brailes, UK
1962 Super Dexta
S/N: 09B725689
Engine: 1610947
Clutch: M9H
Gearbox: M4H
Left Rear Axle: M4H
Right Rear Axle: K23H
Hydraulic Top: L27H
									S/N: 09B725689
Engine: 1610947
Clutch: M9H
Gearbox: M4H
Left Rear Axle: M4H
Hydraulic Top: L27H
Dexta 1
Casting Code L7 F clutch housing: (F almost unreadable)
Serial No. 09B 7?1617 (not guarantee on the number, but the 09B is correct)
Dexta 2,
Casting code clutch housing: M8C
Serial No. 957E 42718 (behind the E barely readable)
Dexta 2,
				greendoglive
serial numbers
Dexta 58??????????
engine 2ckk1372
injectors spe3a605402
957e 7905
c25b
what is my motor and why do the numbers seem to not be found anywhere. The number i obtained from left side near firewall just above sump.
any help greatly appreciated as I am planning on engine work very soon hopefully.
									engine 2ckk1372
957e 7905
c25b
Dexta 1958?
957E 7905
C25B
						957E 7905
C25B
Please do not post queries on here. It is only for a record of tractors.
Numbers like the ones shown are not serial numbers, they are casting numbers and are the same on all tractors. The only numbers cast into castings that mean anything are the C25B that you quote. This dates the component at March 25th 1958 so she is fairly early being three months into full production.
You need the code from the flange behind the starter and as many of the casting codes from the other parts as you can find,
Hello Brian, thanks a lot for the work you  do for us Fordson nerds.
Have been a "hangaround" for a long time, reading the forum and learning a little every day about our old beautys... Live on a small farm in Norway, my Dexta has been mine since 1997, my father bought it in 1966. She is a 59 mod diesel, original with a Horn Draulic loader on. However she was stripped for all that for about 35 years ago.
Serial nr 957E 26259
Engine nr 1427175
Hydr. lift B6C
Clutch housing B23C
Gearbox A29C
Left Axle shaft B23C
Right axle shaft B18C
Rear axle B18C
Engine nr 1427175
Hydr. lift B6C
Clutch housing B23C
Gearbox A29C
Rear axle B18C
				kiwiland dexta
				A.B.Ames
1962 Super Dexta  (w/Ford 2000 sticker on sides)
S/N 09B720950
Engine K72 (plate w/2 screws), 1607571 stamped, 37111510 raised
Clutch K14H
Gearbox K16GH (also a 957E 7??5)
Hydraulic J31H
L-Axle K14H
R-Axle K14H
(note my axles were marked on the rear side not the front as the ser# post said "the rear axle casting code, located on the front side of the rear axle.")
Let me know if I missed anything, or error'd in anyway.
Many Thx,
A.B.Ames
						S/N 09B720950
Clutch K14H
Hydraulic J31H
L-Axle K14H
R-Axle K14H
Many Thx,
A.B.Ames
				The Swanndri Guy
Serial number 09B719xxx
Engine number ?
Clutch H26H
Gearbox K2H
Rear housing ?
Lift cover ?
Left Axle ?
Right axle H21H
1961 Standard Dexta
Serial number 09A313xxx
Engine number 1495xxx
Clutch N15F
Gearbox L26F
Rear housing N15F
Lift cover N10F
Left Axle N10F
Right axle 22J4 (?)
Unknown Dexta
Serial number 09C910127
Engine number ?
Clutch D2J
Gearbox 3D23
Rear housing ?
Lift cover ?
Left Axle ?
Right axle ?
Clutch housing & gearbox only
Engine number ?
Clutch H26H
Gearbox K2H
Rear housing ?
Lift cover ?
Left Axle ?
Right axle H21H
1961 Standard Dexta
Clutch N15F
Gearbox L26F
Rear housing N15F
Lift cover N10F
Left Axle N10F
Right axle 22J4 (?)
Unknown Dexta
Engine number ?
Clutch D2J
Gearbox 3D23
Rear housing ?
Lift cover ?
Left Axle ?
Right axle ?
				Chug-A-Lug
S/N: 09D918971 [1964]
Engine No: ZGKN1372
Clutch Housing No: 4E15
Gearbox No: 4D28
Rear Axel No: P7H [Dec 7th 1962]
Hydraulic Lift No: N29H [Nov 29th 1962]
Axel Trumpet UK Passenger Side: P4H [Dec 4th 1962]
Axel Trumpet UK Driver Side: M11H [Oct 11th 1962]
									Engine No: ZGKN1372
Gearbox No: 4D28
64 super dexta
superdexta
serial no 09D926230
engine no 1631258
clutch no 4D22
trans no 4D20
axel right 3G2
axel left 3J28
hyd lift cover 3M18
						serial no 09D926230
engine no 1631258
clutch no 4D22
trans no 4D20
axel right 3G2
axel left 3J28
hyd lift cover 3M18
				Frustrated
				woodseaves
				npaulz
NZ Blue
1963 Fordson Super Dexta
Blue and red.
Serial number: 09C 908157
Engine number: 1625612
Clutch: M26H
Gearbox: A31J
Rear housing: C 4J
Lift cover: C 4J
Left Axle 3J10 (I swear this is correct. Casting is 957E4013B)
Right axle B27J
						Blue and red.
Clutch: M26H
Gearbox: A31J
Rear housing: C 4J
Lift cover: C 4J
Right axle B27J
