lift asembly arms
lift asembly arms
iam trying to locate a pair of lift arms for the lift ,cover of a dexta, or does anyone know if they can bought new or if the 2000 will fit the dexta . Gerry
- Site Expert Team
Hi Gerald I am i ireland if someone has a set i can be conntected by e mail at [macroibin9@gmail.com] sorry about that , when i set up on new board it was form another computer and i had no email , idont know how to put it on now. Anyway if some one has a set please connect me Gerry
- Site Expert Team
Gerry,
I am almost certain that I have a spare set, I will have to check and establish whether or not they are handed ie, right and left hand.
If you wish to include your e-mail address on this forum, you have to click on "profile" at the top of the forum page which will raise your profile page up on the screen you can then enter your address in the relevant box and confirm by entering your password.
Gerald
Gerald
Gerald i done as you said my daughter,s email is on the profile but when i tried to change it to mine it came up that my email address was baned, why would this be so as it works every where eles
Away that will be great if the arms do you can get me at this email adress macroibin9@gmail.com Bear with me on this as im not great on the computer. Gerry
Lift Arms
I also have a pair that are no longer needed. I'll eventually put them up here with the rest of my redundant kit.
Hi Ambidextarous if you whant to email [ macroibin9@gmail.com ] we could dicuss your pair , iam still exchanging emails with Gerald about his set but as yet we havent come to any arrangment, Gerry
Lift Arms
Hi Gerry, not sure if my Email's working. I've sent a message to your Email address but i may have to send it another way.
Ambidextaous i didnt recive your email , it might also be at my end as iam on wireless singnal ,and this can be between good or bad mostly bad ithink it depends on the weather or something , try it again or if you want give me your email here iwill try an sending it from here, only if this suits you . Gerry
lift asembly arms
I would like to thank tubal cain for his help in getting me fixed up with a set of lift arms and for hassel im sure he had , thanks again Gerry
Ford 2000 Dexta lift arms
Agriline sells them for the Ford 2000, but would it fit?? One could ask them!Nisse wrote:I am lifting this thread as I am looking for at least one of theese (right hand) arms as well. Located in Sweden, but transport from the UK should not be a major problem. I have a Super Dexta
Re: Ford 2000 Dexta lift arms
I asked for the crosshaft and they told me they didn't have any for the Dexta. I told them that the one of the 2000 looks quite similar on the page. So apparently it does not fit. A pity as I found a good one here in sweden.Bensdexta wrote:Agriline sells them for the Ford 2000, but would it fit?? One could ask them!Nisse wrote:I am lifting this thread as I am looking for at least one of theese (right hand) arms as well. Located in Sweden, but transport from the UK should not be a major problem. I have a Super Dexta
But maybe somebody has a 2000 and can take some pictures?
Fordson Super Dexta, John Deere JD400 Backhoe loader
Dexta lift arms
If you look at the respective parts lists:Nisse wrote:I asked for the crosshaft and they told me they didn't have any for the Dexta. I told them that the one of the 2000 looks quite similar on the page. So apparently it does not fit. A pity as I found a good one here in sweden. But maybe somebody has a 2000 and can take some pictures?
Follow the Fordson and NH parts links from http://www.vugot.com/
and enter either Dexta or 2000 as the 'Model', you can see parts for both tractors. It appears that the Dexta and Ford 2000 lift arms are different (despite Agriline's picture)
So suggest you try a breaker or keep looking on ebay - they do come up.
All the best,
The 3000 and super dexta liftingarms have the same chape and lenght. But i dont now if the splines are the same.Nisse wrote:I asked for the crosshaft and they told me they didn't have any for the Dexta. I told them that the one of the 2000 looks quite similar on the page. So apparently it does not fit. A pity as I found a good one here in sweden.Bensdexta wrote:Agriline sells them for the Ford 2000, but would it fit?? One could ask them!Nisse wrote:I am lifting this thread as I am looking for at least one of theese (right hand) arms as well. Located in Sweden, but transport from the UK should not be a major problem. I have a Super Dexta
I also need two lifting arms for super dexta but the one with the extra hole for the hitch.
Ford 3000 -69
ÅLÖ Quicke loader
ÅLÖ snowblower
Fordson Super Dexta -64
MF Robur III -68
ÅLÖ Quicke loader
ÅLÖ snowblower
MF Robur III -68
You'll find these at ebay for incredible prices (do you have the rest of the hitch, or do you need all of it?) You might sell your dexta arms, when you have found the hitch armsI also need two lifting arms for super dexta but the one with the extra hole for the hitch.
@Mervyn. I think South Afrika is a bit too far
I found an arm in Germany but I consider it too expensive for my little dexta. I will wait for a better oportunity. At the moment I am checking the scrapyards in sweden.
Bye, Nils[/quote]
According to the parts lists:Emil Nyman wrote:The 3000 and super dexta liftingarms have the same chape and lenght. But i dont now if the splines are the same.
Super/Dexta & 2000/3000 appear to have different part numbers.
All the best,
Dexta Lift Arms
Thanks for the link! I will keep an eye on them.
Different part numbers between Dexta and 2000 wouldn't be so weired as Fordson became part of Ford
But as I don't think the guys at agriline are stupid, they would have the arms on the dexta page if they were the same. So we say they are different
