I am sure you all know what this part of my '55 FMD is, its attached to the injector pump...as I am new to the mechanical side of the tractor I need a little (LOT) of help. I tried to find it descibed on the manual etc...but its a bit hard if I dont know what its called.
Is it a breather or oil fill?
Does it need maintenance? and should it have a bit of rag stuck in the top of the nozzle?
And whats the big bolt underneath for....
It is nothing to do with the injection pump, it just drives of a skew gear that drives the oil pump. You could take it off and just put a plate on as most Majors have.
The access was there for either an hour meter or proof meter drive.
