Hi all hope this works as my first attempt to post pics and at this stage it just looks like a big sentence?. Anyhow I recently purchased what I suspect from Grill badge is a Fordson Super Major. I was told it has hydraulic issues when I bought it and this is my first quest for possible solutions to the trouble.
I was originally told that it was only the aux bucket that would not function, but since buying it I suspect there may be issues with the rear arms also?. When the selector switch is in and I go to position control as opposed to Qualitrol when I bring the quadrant lever up the rear arms raise and seem to hold. But they will not lower when the quadrant lever is placed in the lower position (does it need weight to lower?)
And as for the aux controls, well when I pull the switch out and select aux and I ensure that the PTO is engaged I cannot seem to get any pressure at all up to the Bucket controls. I did read that I needed the Quad Control lever in a neutral position and have experimented with this and also in and out of qualitrol but still it seems I cannot get pressure to the Aux levers.
Am I wrong in assuming that if I can raise the rear arms then the pump should be ok?, I was hoping it was a configuration/setup problem. I have also played with the Speed Control Adluster (located under the rear/aux selector switch). Have done some reading and read that the unloading valve is a common gremlin, but could not find a post with similar setup to mine?
Am hoping that the ID Plate will help in determining what model I do in fact own. In case my upload pictures do not work the following numbers are what is on the I.D Plate.
Serial Prefix 3R.4,64
Serial Number 11031
Model 94142
Thanks in advance for any replies and offers of advice. I do not work close to home so at times I will not be able to access the Tractor or even the internet but will check in when I can and reply as I progress.
