Power going to dynamo
Gregw
Post by Gregw »
Just changed wiring lume on my fiefdom dexta and there is power going to the dynamo and starts heating it up, what could be wrong?
4x4bobby
Re: Power going to dynamo
Post by 4x4bobby »
Hi. Had the same problem and it burnt out the dynamo. Turned out I had connected the wires round the wrong way at the regulator box.
Give it a check and get the dynamo checked as well. It burnt out the commutator in the dynamo.
Post by Jerry Coles »
Have you "Flashed" the Dynamo? If it is polarised (Flashed) the wrong way it can be catastrophic.
Knew a chap who replaced the Dynamo on a Ford Taunus (V4) and didn't realise the Dynamo rotated anti-clockwise. He burnt out several Dynamo's and control boxes before I spotted that the cooling fan vanes were set the opposite way. had to reverse flash the latest dynamo to it worked correctly!!
