when i stripped my diesel major hydraulics i took apart the lift lever as it leaked and was very gungy.
having put a new seal on rear of pin that holds lift and lower lever, i still have a good leak from where pin comes out of ally casing on the front side, there is no seal or o ring on this side so how can i stop it leaking.
thanks in advance brett
i guess that can be only problem , but not sure quite how to solve the problem, i dont think instant gasket will work as the pin is always moving back and forth.
